"vmx.reboot.powerCycle=True". However, post scheduled reboot the VM did not power on back automatically./vmfs/volumes/<Datastore-Name>/<VM-Name>/vmware.log, similar log entries will be seen
YYYY-MM-DDTHH:MM:SS.###Z In(05) vcpu-0 - Chipset: The guest has requested that the virtual machine be hard reset.YYYY-MM-DDTHH:MM:SS.###Z In(05) vcpu-0 - Chipset: hard reset being turned into a power cycle.YYYY-MM-DDTHH:MM:SS.###Z No(00) vcpu-0 - ConfigDB: Setting softPowerOff = <not printed>YYYY-MM-DDTHH:MM:SS.###Z No(00) vcpu-0 - ConfigDB: Setting virtualHW.scheduledUpgrade.poweredOffNeedsPowerOn = <not printed>YYYY-MM-DDTHH:MM:SS.###Z No(00) vcpu-0 - ConfigDB: Setting vmx.reboot.powerOffTriggered = <not printed>YYYY-MM-DDTHH:MM:SS.###Z In(05) vcpu-0 - VM reset: Power cycle on reboot requested./var/run/log/hostd.log, similar log entries will be seen
YYYY-MM-DDTHH:MM:SS.###Z Db(167) Hostd[###]: [Originator@6876 sub=Vmsvc.vm:/vmfs/volumes/vsan:<UUID>/<VM-Object-UUID>/<VM-Name>.vmx opID=HB-SpecSync-host-##@UUID sid=52230749 user=vpxuser:<no user>] Preparing resource pool updateYYYY-MM-DDTHH:MM:SS.###Z In(166) Hostd[###]: [Originator@6876 sub=Vmsvc.vm:/vmfs/volumes/vsan:<UUID>/<VM-Object-UUID>/<VM-Name>.vmx opID=HB-SpecSync-host-##@UUID sid=52230749 user=vpxuser:<no user>] State Transition (VM_STATE_ON -> VM_STATE_RECONFIGURING)YYYY-MM-DDTHH:MM:SS.###Z Db(167) Hostd[###]: [Originator@6876 sub=Vmsvc.vm:/vmfs/volumes/vsan:<UUID>/<VM-Object-UUID>/<VM-Name>.vmx opID=HB-SpecSync-host-##@UUID sid=52230749 user=vpxuser:<no user>] Completing resource pool updateYYYY-MM-DDTHH:MM:SS.###Z Db(167) Hostd[###]: [Originator@6876 sub=Vmsvc.vm:/vmfs/volumes/vsan:<UUID>/<VM-Object-UUID>/<VM-Name>.vmx opID=HB-SpecSync-host-##@UUID sid=52230749 user=vpxuser:<no user>] Created power off monitor: security domain=###; verify=false; needsPowerOn=false; task=<none>.YYYY-MM-DDTHH:MM:SS.###Z In(166) Hostd[###]: [Originator@6876 sub=Vmsvc.vm:/vmfs/volumes/vsan:<UUID>/<VM-Object-UUID>/<VM-Name>.vmx opID=HB-SpecSync-host-##@UUID sid=52230749 user=vpxuser:<no user>] State Transition (VM_STATE_RECONFIGURING -> VM_STATE_OFF)ESXi 7.x, ESXi 8.x
The virtual machine shutdown process overlapped with another management operation specifically, a resource reconfiguration triggered by host synchronization. This conflict can also occur during other operations such as snapshot creation or modification. Due to the simultaneous tasks, the VM may not restart automatically after shutdown.
Engineering Team is aware of this issue and will be fixed in future release.
