Generic System Error When Creating WIP Adjustment With Exchange Rates
Article ID: 400148
Clarity PPM On Premise
When creating a WIP adjustment gives a generic error with no details on how to fix.
This happens when adjusting the transaction and changing the currency to one where there is no bi-directional currencies set up in Foreign Exchange Rates
Steps To Reproduce
1.  Create Exchange Rates
  • BRL to USD
  • USD to BRL
and
  • INR to USD
  • USD to INR
Do not create one BRL to INR as we want to adjust from BRL to INR
2. Create  a transaction using BRL currency
2. Post the transaction to WIP.
3. Make an adjustment, such as role and rate and
4. Change the currency to INR
5. Save
Expected: The adjustment should be accepted.
Actual: The adjustment is not accepted but does not give detail about why it is not accepted.
There is a generic error: System error. Contact System administrator.
Logs (app-ca and bg-ca) do not have any information.
1. Check if  involved country/currency rate exchange exists.
The following query can be used:
select * from CMN_EXCHANGE_RATES
If bi-directional rate exchanges do not exist, proceed to create them, e.g.
INR to USD, USD to INR
If you do not want to create the new bi-directional rates 2 WIP adjustments are needed to bridge the gap.
1. WIP adjustment #1
  • Change the quantity and the currency from BRL to USD (as there is a bi-directional match for this)
  • Click the Calculate New Rates box (required)
  • Save and Approve WIP Adjustment
2. WIP Adjustment #2
  • Follow the same steps changing the currency from USD to INR
  • Click the Calculate New Rates box again (required)
  • Save and Approve
