CAVerizonPEStats camm engine not working correctly after upgrade
Article ID: 400066
CA Mediation Manager Network Observability
CAVerizonPEStats camm engine not picking up files as expected after upgrade.  The following is seen in the log:
SEVERE: Fatal Exception occurs in Engine
java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at com.torokina.tim.classloader.TimBootstrap.bootstrap(TimBootstrap.java:80)
at com.torokina.tim.engine.Main.main(Main.java:197)
Caused by: java.net.BindException: Address already in use
at java.base/sun.nio.ch.Net.bind0(Native Method)
at java.base/sun.nio.ch.Net.bind(Unknown Source)
at java.base/sun.nio.ch.ServerSocketChannelImpl.netBind(Unknown Source)
at java.base/sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
at io.netty.channel.socket.nio.NioServerSocketChannel.doBind(NioServerSocketChannel.java:141)
at io.netty.channel.AbstractChannel$AbstractUnsafe.bind(AbstractChannel.java:561)
at io.netty.channel.DefaultChannelPipeline$HeadContext.bind(DefaultChannelPipeline.java:1331)
at io.netty.channel.AbstractChannelHandlerContext.invokeBind(AbstractChannelHandlerContext.java:600)
at io.netty.channel.AbstractChannelHandlerContext.bind(AbstractChannelHandlerContext.java:579)
at io.netty.channel.DefaultChannelPipeline.bind(DefaultChannelPipeline.java:972)
at io.netty.channel.AbstractChannel.bind(AbstractChannel.java:259)
at io.netty.bootstrap.AbstractBootstrap$2.run(AbstractBootstrap.java:380)
at io.netty.util.concurrent.AbstractEventExecutor.runTask(AbstractEventExecutor.java:173)
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:166)
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:469)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:569)
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:994)
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74)
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30)
at java.base/java.lang.Thread.run(Unknown Source)
Seen after upgrade to 24.3.8
The port on which the ENGINE is attempting to start is already in use. This may indicate that a previous ENGINE restart did not complete successfully.
You can verify the ENGINE port from the CAMM console.
The port typically starts from 29100 and increments depending on the number of engines configured.
To terminate the process on the relevant LC, execute the following command:
  • kill -9 $(lsof -t -i:291xx (Replace 291xx with the actual port number in use.)
Alternatively you  can do
  •  /opt/CA/CAMM/tools/stopall
  •  /opt/CA/CAMM/tools/startall
