[root@Hostname/var/log] localcli storage filesystem listGetUnmountedVmfsFileSystemsInt: fsUUID is null, skipping naa.#############################02:1
[root@Hostname:/] vmkfstools -P -h /vmfs/volumes/Datastore1VMFS-6.82 (Raw Major Version: 24) file system spanning 2 partitions.File system label (if any): Datastore1Mode: publicCapacity 15 TB, 7.0 TB available, file block size 1 MB, max supported file size 64 TBDisk Block Size: 512/512/0UUID: ########-########-####-############Partitions spanned (on "lvm"): naa.##############################01:1 naa.##############################02:1
In a multiple extent configuration one or more storage devices backing the datastore fails to establish the connectivity to the ESXi host after a power outage which leads the datastore lose the connectivity to ESXi host and report missing.
Rescanning of storage devices and adapters from host UI helps in getting the storage device connectivity established on ESXi host.
Rescanning may work only when the iSCSI connectivity issues are fixed.
All shared iSCSI datastores missing from a single ESXi Host
