We are facing an error while navigating to Portlet Definition. Error is specific to certain custom portlets. Some portlet links open fine, but others error out.
Steps to reproduce:
1. Go to Classic.
2. Go to Administration -> Studio -> Portlets.
3. Search for a portlet in Portlet Name.
4. Click on Portlet Name, get an error below.
Clarity 16.3.1
ERROR 2025-05-15 13:53:38,626 [http-nio-8080-exec-649] niku.xql2 (clarity:some_user.com:session_id:npt.gridPropertiesEntry) Internal Processing exception
com.niku.odf.griphendor.GriphendorException: Unable to find grid metadata with view code/portlet id = xxxxxxx
at com.niku.odf.griphendor.grid.GridAdminHandler.postProcess(GridAdminHandler.java:288)
at com.niku.xql2.XQLVisitor.postProcess(XQLVisitor.java:1440)
By referencing the query in this KB you can identify the NSQL query used for a given portlet and then ensure it is valid and does not produce any errors.
