Virtual Machine fails to power on with the following error message:
"Cannot open the disk ‘/Users/<User_Name>/Virtual Machines.localized/<VM_Name>/<VM_Name>.vmdk’ or one of the snapshot disks it depends on. Module ‘Disk’ power on failed. Failed to start the virtual machine."
VM went down abruptly, and the disk lock was not removed.
Follow the steps shared below to delete the unexpected lock file (.lck) and power on the VM:
