After creating a backup of the production database, a load in the certification MUF failed with this message:
DB13001E - UNEXPECTED RETURN CODE 21 (73) COMPRESSION EXIT GAVE BAD RC
A review of CXX information from the two MUFs showed that the table had two different lengths:
Production MUF MUF Certification
TABLE NAME - D12 TABLE NAME - D12
TABLE ID - 12 TABLE ID - 12
RECORD LENGTH - 200 / 212 RECORD LENGTH - 350 / 362
The problem here was caused by taking a backup with one record layout and then trying to load it to a different, longer record layout.
Here are some things to think about with this situation.
The main point here is that you cannot use either a BACKUP file or an EXTRACT file from the Production MUF to LOAD into the Certification MUF without some kind of special processing to adjust the record length of the data being loaded.
As always, please contact Broadcom support for Datacom if you have further questions.
