Web-Link pagination does not work for ConnectALL Universal Adapter
Article ID: 396392
ConnectALL ConnectAll On-Prem ConnectAll SaaS
Steps to Reproduce:
  1. Create a Universal Adapter for an application that uses web-links for pagination, such as GitHub.
  2. Configure the Pagination in the Universal Adapter as per the 3rd party application's documentation. See attached screenshot.
  3. Create an automation that includes the Universal Adapter and attempt to sync the records.
Expected Result:
Records should Sync fine
Actual Result:
Records are found in the poll.
A null pointer is thrown and all activity stops.
3.7.x
DE169215
DE169215 is fixed in 3.9.0 and ported back in 3.8.1 patch
