Ingress Traffic option after enabling NSX Tenancy for an Org inside VCD that have been defined in the NSX-T. You will get the following error:Gateway QoS Profile with ID <Profile Name> not found in NSX-T manager. "error_code" : 500045 in response for GET /policy/api/v1/orgs/default/projects/89e7####-####-####-####-############/infra/gateway-qos-profiles/1000_Mbps with status 404 after execution 1:{ "httpStatus" : "NOT_FOUND", "error_code" : 600, "module_name" : "common-services", "error_message" : "The requested object : /orgs/default/projects/89e7####-####-####-####-############/infra/gateway-qos-profiles/<Profile Name> could not be found. Object identifiers are case sensitive."VMware Cloud Director 10.6.1.
This is a known issue in the mentioned version of VMware Cloud Director.
Cloud Director Engineering are aware of the issue and are actively evaluating for inclusion in a future patch of Cloud Director.
Workaround
Disabling NSX Tenancy for the Org will allow you to edit the Rate Limiting for the NSX-T edge in VCD.
