Introduction:
Problems with the ECLI running commands on autosys server results in Command not found or could not execute.
Question:
When tired to execute an AutoSys command from the ECLI got an error indicating the command could not be executed.
In WCC CommandApp.log, we found the following message:
com.ca.uejm.command.client.autosys.AutoSysCommandClient IclException while calling sponsor 404 Error
We tried restarting igateway. It did not help.
Environment:
11.1 through 11.4.x on All platforms of WCC
Answer:
Restarting the Application server helped restore the connection between WCC and the Autosys Application server.
