Host volume greater than interface volume for given time period
Article ID: 3946
CA Application Delivery Analysis MTP (NetQoS / ADA) CA Infrastructure Performance
Hosts from the Host Summary view report traffic volume inconsistent with the selected interface speed. In the example below, the speed of the link is 128 Kbps and the time period of the report is 24 hours. An interface with 128 Kbps of data transfer can transfer approximately a maximum of 1.38 GBytes of traffic volume ( (128000/8)*60*60*24 ).
<Please see attached file for image>
Figure 1
RA 9.0.161 only.
This issue occurs when data from disabled and unlicensed interfaces is being loaded into other enabled and licensed agents. That is, an interface that says Enabled: No on the enable interfaces page, and has never been added to the various agents tables in the past either (thus using a license). This is due to Defect 26345 with RA 9.0.161. To resolve this issue, please follow the steps below:
  1. Download the following ZIP file onto the RA master console or standalone server:
    https://ftp.broadcom.com/user/downloads/pub/netqos/product_patches/RA/9.0/26345/pump2.zip
  2. Stop the NetQoS ReporterAnalyzer Pump service on the RA master console or standalone server.
  3. Back up the entire folder D:\netqos\reporter\NetQoS.ReporterAnalyzer.PumpService\bin to another location.
  4. Extract the files in the ZIP to D:\netqos\reporter\NetQoS.ReporterAnalyzer.PumpService\bin, overwriting the current files.
  5. Start the NetQoS ReporterAnalyzer Pump service again.
Note that RA 9.0 is no longer supported we recommend upgrading to a supported release as soon as possible.
For more information about product life cycle dates see the link below:
https://support.ca.com/us/product-content/status/support-life-cycle/ca-network-flow-analysis-r9_1-sp1-r9_1-ca-netqos-reporteranalyzer-r9_0-sp1-r9_0-eos-announcement.html
For tips on how to upgrade see the link below:
https://communities.ca.com/docs/DOC-231155322
1558708344372000003946_sktwi1f5rjvs16r1r.gif get_app
