When NSX edge is running on an ESXi host with Mellanox network cards, there may be some packet drops observed on the ESXi host's vmnics.
Using command /usr/lib/vmware/vm-support/bin/nicinfo.sh on the ESXi host, there are "Receive packets dropped" on the vmnic which also matches "ring full" counter.
An example:
NIC statistics for vmnic2:
Packets received: 15576594101
Packets sent: 1427162519
Bytes received: 5972134130612
Bytes sent: 2698821449768
Receive packets dropped: 17242488
Transmit packets dropped: 0
NIC Private statistics:
outOfBuffer: 17242488
....The number of packet drops may be even higher when NSX edge is running in a host with mix-workloads (NSX edge on the same host as other workload VMs).
Any services running on the edge node, especially services for North-South traffic, may see network connection dropping or flapping, such as IPSec VPN tunnel and BGP connections.
VMware NSX
VMware NSX-T Datacenter
This is caused by problematic Mellanox driver/firmware.
To resolve this issue, confirm Mellanox driver/firmware version is on Broadcom Compatibility Guide matching the ESXi version. A guide to determine hardware ID can be found here.
In the event that the driver/firmware version matches the compatible version showed in Broadcom Compatibility Guide, it is advised to update the driver/firmware version to the newer version also listed in the compatibility list.
If the condition does not improve, please contact Broadcom Support and upload the support bundles for the following:
