Issue with multi-line selection in "Help - About" on Firefox
Article ID: 394454
CA Automic Workload Automation - Automation Engine
In the Automic Web Interface (AWI) v24 when accessing the Help > About dialog in Firefox it is not possible to select and copy multiple lines of text from the "About" window. The selection is limited to one line at a time.
In contrast, using Google Chrome and Microsoft Edge, multi-line selection works without issues, and all information can be marked and copied as expected.
This works fine in AWI 21.x but not in AWI 24.2,24.3,24.4 or 24.5
Automic Web Interface 24.x
Browser: Firefox
DE167863
Update to a fix version listed below or a newer version if available.
Fix version:
Component(s): Automic Web Interface (AWI)
Automation.Engine 24.4.2 - Planned release October 2025
Public Title: Selection problems in About dialog
Public Description: A problem has been fixed that blocks the selection of multiple lines in the About dialog
