MUX copy project does not copy some attributes values from Team Object
Article ID: 393182
Clarity PPM SaaS
In MUX when using Copy project, all custom and some out-of-the-box attribute values on the Staff page are not copied.  Attribute values on the Task and Assignment pages are copied.
STR:
1.  In Studio, create a custom attribute (string) on the Team object.  Enable it for MUX by adding API Alias.
2.  In MUX open an investment (project in this example) and go to the Staff Module.
3.  Add the custom attribute to the staff grid
4.  Type some values into a few lines.  If there is no staff, add staff first.
5.  Go back to the Projects Workspace list (grid)
6.  On the project you just edited, either Right Click and Select Copy or choose the project's checkbox and choose Copy from the options above
7.  Once completed, open the new project and check for the values on the Staff module.
Expected Result:  Values copy over
Actual Result:   Values are not copied and the field has blank values.
Workaround:  None.
Reported as DE168796. Fix targeted for 16.3.3
