In the /var/log/vmkernel log file, there are entries similar to:
WARNING: NFSLock: ####: File is being locked by a consumer on host <ESXi hostname-01> with read-only lock.
VMware vSphere ESXi 7.0.3
There is this VM process running on <ESXi hostname-01>. Example: lsof | grep <Virtual Machine Name> #### hostd FILE ## /vmfs/volumes/<Datastore>/<Virtual Machine Name>/####-flat.vmdk
