When attempting to pass through NVSWITCH PCI devices to a virtual machine, users may experience a situation where the VM consistently fails to boot and the NVSWITCH device disappears from the ESXi host's PCI device list after each failed attempt. This forces administrators to reboot the host to restore visibility of the NVSWITCH device. The issue particularly impacts environments where NVIDIA GPUs and NVSWITCH devices are used together for high-performance computing applications.
Typically, after each VM power-on attempt, users observe that:
- The VM fails to power on with a "Module DevicePowerOn power on failed" error
- The NVSWITCH device that was assigned for passthrough is no longer visible in the host's hardware list
- Subsequent attempts to power on the VM fail with the same pattern, with more devices potentially disappearing
- A host reboot is required to restore visibility of the NVSWITCH devices
Other errors and log messages may include:
The issue occurs because some PCIe slots are incorrectly configured for hotplug by the firmware, despite not having proper hardware support for out-of-band device presence detection. Instead, they use in-band presence detection, which is not officially supported by VMware or recommended by PCI-SIG.
During VM power-on, the PCI passthrough process attempts to reset the device, which triggers a link reset. When the link goes down during this reset, the hotplug-enabled slot incorrectly reports that the device has been removed. This results in a hotplug event on the host, causing the device to be removed from the system unexpectedly.
This issue is verified resolved by an update to ESXi Update 3e or newer.
The following work-around resolves this issue if an upgrade to U3e or newer can't be performed::
Disable PCIe hotplug system-wide:
esxcli system settings kernel set -s "enablePCIEHotplug" -v "FALSE"
Note: This workaround will disable hot-plug capability for all PCIe devices on the host, meaning you won't be able to add or remove PCIe devices without rebooting the host. However, for environments affected by this issue, this limitation is typically acceptable as it resolves the critical problem with NVSWITCH devices disappearing.
Critical Requirement: When using GPU passthrough mode (DirectPath I/O), ALL GPUs that are physically connected to each other through NVLink must be assigned to the same VM, regardless of whether you intend to use NVLink functionality or not. This is a hardware and driver limitation from NVIDIA, not a VMware restriction.
Why This Requirement Exists: If only a subset of NVLink-connected GPUs is passed through to a VM, an unrecoverable XID 74 error occurs when the VM boots. This error corrupts the NVLink state on the physical GPUs and renders the NVLink bridge unusable, requiring a GPU reset or host reboot to restore functionality.
For Systems with NVSwitch Technology:
VMware supports GPU passthrough as documented in this KB article. For other GPU virtualization methods and their specific configuration requirements, please refer to NVIDIA's official documentation and support channels, as these configurations fall under NVIDIA's support domain.
Before configuring GPU passthrough:
nvidia-smi topo -m on the ESXi host to view the NVLink topologyWhen using NVSWITCH devices for NVLink functionality, add these advanced parameters to your VM configuration:
pciPassthru.allowP2P = "TRUE"pciPassthru.use64bitMMIO = "TRUE"pciPassthru.64bitMMIOSizeGB = "256" (increase if needed for multiple high-memory GPUs)For H200 GPUs with large video memory (141GB each) and NVSwitches, you may need to set a larger MMIO space. For example, with 8 H200 GPUs (141GB × 8 = 1,128GB), set pciPassthru.64bitMMIOSizeGB = "2048" (next power of 2).
If problems persist after implementing the hotplug workaround:
nvidia-smi nvlink --status to verify NVLink connectivity status
