Need API call to create an edge between two components (router interfaces)
Article ID: 391404
DX Operational Intelligence DX Operational Observability
What's the API call to create an edge (==connection) between two components (router interfaces)
  • DX O2 SaaS
  • DX O2 OnPremise
Currently, manually creating a relationship from a device to an interface is not supported. In DXO2, interfaces are not yet available.
None
