SpectroSERVER will not start CORBA::NO_PERMISSION or CORBA::TIMEOUT errors
Article ID: 391323
Network Observability Spectrum
When starting the SpectroSERVER it does not properly start and the $SPECROOT/SS/VNM.OUT shows:
Mar 18 17:58:14 ERROR TRACE at CsCorbaMgr.cc(1271): Exception: CORBA::TIMEOUT
Minor: 1447165953
Completion Status: NO
Mar 18 17:58:14 ERROR TRACE at CsCorbaMgr.cc(1271): Exception: CORBA::NO_PERMISSION
Minor: 1447165953
Old NAMINGSERVICE.IDB file in use.
Review the $SPECROOT/lib/SDPM/partslist/NAMINGSERVICE.IDB file.  Make sure it is current to the release that is installed.  You can review the date with a listing of the directory to see if the file was modified.
Often this issue occurs when an upgrade is done and the entire $SPECROOT/lib/SDPM/partlist folder is replaced with the old directory.  Restart processd and it errors.
Replace the *.idb files with the originals from the installation version you are running.  Generally this will be the idb files with java references:
NAMINGSERVICE.idb
NCMSERVICE.idb
TELNETD.idb
Restart processd:
systemctl stop processd
systemctl start processd
If you do not have a server that has the current files (they have all been overwritten), open a Broadcom Support ticket and an engineer will assist you with providing the default files for the version you are running.
If this does not resolve the issue, you may need to disable secure corba:
https://knowledge.broadcom.com/external/article?articleId=112340
