Operation failed!Task name Power On virtual machineStatus No host is compatible with the virtual machine.
VMware vSphere ESXi 8.0.x
VMware vSphere ESXi 7.0.x
Enabling SCAv1 will result in the vSphere UI reporting only a single logical processor per physical core that halving the number of logical processors if Hyperthreading was previously enabled. In addition Hyperthreading may be reported as 'Disabled' in various configuration tabs. If the virtual machine previously configured vCPU more than physical core, it will not power on due to insufficient logical cores.
