VM fails to power on with the error:
Operation failed
Task name: Power On virtual machine
Target: <VM_Name>
Status: License key has expired
VMware vSphere ESXi 8.x
This issue caused by an invalid or expired license assigned to the ESXi host.
Verify the ESXi host License:
Check if the ESXi host is assigned a valid license.
If the license is found to be invalid or expired, assign a valid license and attempt to power on the VM.
If the issue persist please open a case with Broadcom Support
