Creating a Calculation Metric on Hierarchy on OOTB TSV labor_act (Hours) and a custom TSV field (Hours) does not work as Clarity is also matching workEffortUnit Extended Type attribute which is null for all custom TSVs. OOTB TSVs like labor_act have an invisible Extended Type set to Seconds. Custom TSVs have no workEffortUnit set, and it is null, which causes the validation failure.
STEPS TO REPRODUCE:
Expected Results: The Calculation Metric to be added as the labor actual units are in Hours and the new custom TSV unit is in Hours and they are set identically
Actual Results: Error in UI “Metric One and Metric Two must be of the same data type.”, message in logs is Metric One and Metric Two must have same Work Effort Unit.
Error in logs:
ERROR 2025-02-25 06:59:49,928 [http-nio-1630-exec-570] object.HierarchyCalcAttributeInstance (clarity:admin:5557074__C291F80C-9869-46E1-AB5D-8DB210842CEA:PPM_REST_API) (0c35786b-b947-4b9d-b1bd-be2939d706bc) Metric One and Metric Two must have same Work Effort Unit.
ERROR 2025-02-25 06:59:49,929 [http-nio-1630-exec-570] rest.validation (clarity:admin:5557074__C291F80C-9869-46E1-AB5D-8DB210842CEA:PPM_REST_API) (0c35786b-b947-4b9d-b1bd-be2939d706bc) ODFResourceProvider :: Could not create resource. Object code alias: [ requestUrl: http://XXXXXXXXXXXXXXXX/ppm/rest/v1/private/hierarchyCalcAttributes , _restResourceName : hierarchyCalcAttributes , _id : null , _parentInfo : null , _apiVersion : v1 , _includeLinksArray : true , _contextId : -1 , _hierarchyId : 5003002 , _isGroupBy : false , _isPartition : false]
ERROR 2025-02-25 06:59:49,929 [http-nio-1630-exec-570] rest.validation (clarity:admin:5557074__C291F80C-9869-46E1-AB5D-8DB210842CEA:PPM_REST_API) (0c35786b-b947-4b9d-b1bd-be2939d706bc) ExceptionInfo :: Could not create resource. Resource name: hierarchyCalcAttributes. Error code: odf.hierarchyMismatchedAttributes Error message: Metric One and Metric Two must be of the same data type.
Note: Comparing labor_act to a custom TSV in Seconds will also not work
Clarity 16.2.3, 16.3.0, 16.3.1
DE166801 (Works as Designed)
