Edge running 5.0 software is not responding to SNMP v2 when there are multiple community strings configured.
Article ID: 388459
VMware VeloCloud SD-WAN
Edge is not responding to SNMP v2.
VCO version 5.1 or higher
VCE version 5.0 and lower|
SNMP v2
VCO allows for the configuration of multiple community strings, but the edge only responds to the first value in the list.
The support for multiple community strings was added in 5.1 software.
This went in release_5.1.0 (both VCO and VCE).
But then under scenarios where VCO is 5.1.0 and VCE is less than 5.1.0, VCO ends up sending a list of community strings.
This is fine for VCE 5.1.0 and above, for older VCE releases this will break SNMP.
    With edges running software below, 5.1, use only 1 community string for SNMP v2
    Release 5.1.0 adds the following enhancements to SNMP:
    • SNMPv2, support for additional community strings and 64-bit counters.
