Load DWH job fails after Enable Plan Actuals is set to 1
Article ID: 388155
Clarity PPM SaaS Clarity PPM On Premise
After enabling DWH Plan Actuals toggle, and running Update Financial Plan Actuals job, Load Data Warehouse fails with ERROR: cannot change data type of view column "transaction_class" from character varying to character varying(2100)
STEPS TO REPRODUCE:
  1. Set up Clarity with PG and DWH
  2. Ensure Load DWH Full is running successfully
  3. Now enable  Enable Plan Actuals Toggle for Financial Period Plan Facts
    • updatedwh_settings set enable_plan_actuals = 1;
    • commit
  4. Run Update Financial Plan Actuals job to completion
  5. Run Load Data Warehouse – Full Load
Expected Results: the job to complete Successfully
Actual Results: Load DWH job fails with error
2025/02/12 14:30:23 - Refresh Matl View - ERROR: cannot change data type of view column "transaction_class" from character varying to character varying(2100)
  Where: SQL statement "CREATE OR REPLACE VIEW dwh_fin_plan_virtual_v
Clarity 16.3.0, 16.3.1
DE166204
Fixed in 16.3.2
