Need help with MySQL monitoring using the Infrastructure agent
Article ID: 387101
Updated On: 01-30-2025
CA Application Performance Management (APM / Wily / Introscope)
On one monitored MySQL host, I’ve managed to get the MySQL status to show via the apim extension but the logs are flooded with errors around SecureSpan.
I have the MySQL server locked down to only SSL connections and I don’t see anything in the documentation around making an SSL connection.
I entered the id/password in the ../extensions/MySQL/bundle.properties file and loaded “MySQL” into the ../extensions/Extensions.properties file but still nothing is showing in the investigator.
Fixed in 25.1
