Edge model 720 goes offline shortly after activated with code the version 5.2.3.
In the event message, we see this:
Installed downloaded software on edge VC0720XXXXXXX045 version 5.2.3.0 build R5230-20240313-GA-da68480549 into partition 2
In the VCO, the edge shows code 5.2.4.0. Also, it has MR in the version name, which means it is a factory code.
Edge 720 is only compatible with releases 5.2.4 and above.
Details of the platform specifications is below:
https://www.vmware.com/docs/sdwan-712-edge-platform-spec-ds-1020
We need to change the code to 5.2.4+ in the VCO then proceed with activation.
