Configuring Virtual Machine Advanced Parameter property using OVF template
Article ID: 384261
VMware vSphere ESXi
Some virtual machine advanced configuration parameters are not updating to the VM after deploying from OVF Template.
VMware vCenter server
VMware ESXi
Configuring any VM Advanced Parameter (in this case e.g.  "ethernetX.udpRSS = "1" ) via OVF template so that it can be automatically updated during VM deployment:
Edit the required OVF descriptor file (i.e. <VM-Name>.ovf) and add below entry:
You can put this property under "<VirtualHardwareSection>" :
 <vmw:ExtraConfig ovf:required="true" vmw:key="ethernetX.udpRSS" vmw:value="1"/>
OR
Manually add required 'Advance Parameter' to the VM (Edit Settings) -> Convert that VM to OVF Template -> check whether required property exist in .ovf file
