When trying to open the Admin Console HUB GUI I get:
Message: Internal server error: Adapter hub failed generating representive model of inventory for hub
Resolution: Please check the ppm.log file
Error code: PPM-011
Error in ppm.log:
nov 27 10:49:35:709 [attach_socket, ppm] (hub) Instance data population for adapter '/<>domain/<>_hub/<hubrobot>/hub' failednov 27 10:49:35:710 [attach_socket, ppm] (37) , Wrong type, the element type is String (7)
All other Probe GUI Can be opened correctly.
I can also open another hub GUI, it' is failing only on one hub.
DX UIM 23.4.*
Secure robot accidentally installed on the hub.
To check if this is the cause verify the controller.log start if if looks like this:
Dec 2 16:30:31:848 [3304] 0 Controller: ----- Robot controller 23.4.0.S [Build 23.4.0.S.1048, Jan 4 2024] started -----
This would also cause IM not to work.
Downgrade the robot to non-secure by installing the non secure robot_update back to the affected hub.
After a hub restart the issue should be fixed. the HUB GUI from AC and the IM should be accessible again.
