Ghost Solution Suite remote console error connecting to database
Article ID: 382891
Updated On: 11-26-2024
Ghost Solution Suite remote console install is successful but fails to connect or find the database when launching the remote console
Ghost Solution Suite 3.x
The Ghost Solution Suite database server is not listening on port 1433 and appears to be configured for dynamic port
Log in to the SQL Server configured for GSS using an account with full administrator rights
Open SQL Server Configuration Manager, expand SQL Server Network Configuration, and select 'Protocols for MSSQLSERVER'
Ensure TCP/IP Protocol is 'Enabled', right click TCP/IP and select 'Properties'
Select the 'IP Addresses' tab and change 'TCP Port' to 1433 for any/all 'Active' IPx sections
Make sure each 'TCP Dynamic Ports' field is blank to disable Dynamic ports
Log on to the remote console computer with an account that has rights to the GSS eXpress DB and open ODBC Data Source Administrator (32-bit)
Configure ODBC with settings from the following Techdocs article:
Connecting to another Ghost Solution Suite server
Ensure the ODBC entry is configured to connect to the GSS DB on port 1433 (client configuration settings)
Launch the GSS remote console. If further issues are seen, contact support
