Move robots to another hub using a probe utility callback in DX UIM
Article ID: 382333
Updated On: 11-19-2024
We would like to move robots, similarly to what we do in Infrastructure Manager (IM) by right-clicking on the robot and select "move", but with a probe utility callback.
Is there a callback to move robots to another hub or domain?
DX UIM 20.4 or later
Guidance
The controller callback called "sethub" does the same operation as the "Move..." IM GUI option:
Sethub callback requires the following minimum parameters to be filled:
hubdomain
hubname
hub_dns_name (or hubIp)
hubport
