"Module 'Disk' power on failed" / "Plugin loading error" when attempting to power on a VM
Article ID: 382016
VMware vSphere ESXi
  • Virtual machine will fail to power on after removing an IO Provider VIB from the managing ESXi host
  • Attempting to Powering ON the VM fails with an error similar to the below.
  • From the /var/run/log/hostd.log file:
    Power on failed: (vim.fault.GenericVmConfigFault) {
       faultCause = (vmodl.MethodFault) null,
       faultMessage = (vmodl.LocalizableMessage) [
          (vmodl.LocalizableMessage) {
             key = "msg.iofilter.pluginError",
             arg = <unset>,
             message = "Plugin loading error"
             key = "msg.disk.noBackEnd",
             arg = (vmodl.KeyAnyValue) [
                (vmodl.KeyAnyValue) {
                   key = "1",
                   value = "/vmfs/volumes/<datastore_id>/<vm_folder>/VMNAME_1.vmdk"
             message = "Cannot open the disk '/vmfs/volumes/<datastore_id>/<vm_folder>/VMNAME_1.vmdk' or one of the snapshot disks it depends on. "
             key = "msg.moduletable.powerOnFailed",
                   key = "1",
                   value = "Disk"
             message = "Module 'Disk' power on failed. "
             arg = <unset>,
                   key = "1",
                   value = "/vmfs/volumes/<datastore_id>/<vm_folder>/VMNAME.vmdk"
             message = "Cannot open the disk '/vmfs/volumes/<datastore_id>/<vm_folder>/VMNAME.vmdk' or one of the snapshot disks it depends on. "
             key = "msg.vmx.poweron.failed",
             arg = <unset>,
             message = "Failed to start the virtual machine."
       reason = "Plugin loading error"
       msg = "Plugin loading error"
  • When we review the vmdk descriptor files for the vmdk's in the error above, they contain references to the removed IO Filter provider as shown in below example:
    db.adapterType = "lslogic"
    db.deletable = "true"
    db.geometry.cylinders = "######"
    db.geometry.heds = "##"
    db.geometry.sectors = "##"
    db.iofilters = "<iofilter_name>"   <--- HERE
    db.logContentID = "###########"
    db.sidecars = "<iofilter>, <VMNAME_#-#####>.vmdk"    <--- HERE
    db.thinProvisioned = "#"
    db.toolsInstallType = "#"
    db.toolsVersion = "#####"
    db.uuid = ## ## ## ## ## ## ## ##-## ## ## ## ## ## ## ## "
    db.virtualHWVersion = "##"
vSphere 7.x , 8.x
This issue occurs when references of the IO Provider are still present in the VM's VMDK descriptor file even after the IO filter has been removed
To resolve this issue , remove IO filter provider from the vmdk descriptor files.
  • Using "vi" edit command, Remove the IO filter provider line entries from the VMDK descriptor files for virtual machines with more than one VMDK attached
    After Edit
    db.geometry.cylinders = "294084"
    db.geometry.heds = "255"
    db.geometry.sectors = "63"
    db.logContentID = "208e80f99f756c948df2da1c1ca6b10"
    db.thinProvisioned = "1"
    db.toolsInstallTpe = "1"
    db.toolsVersion = "12389"
    db.uuid = "## ## ## ## ## ## ## ##-## ## ## ## ## ## ## ##"
    db.vertualHWVersion = "4"
Note:  DO NOT edit the descriptor without having a backup of it first.  Copy the descriptor file to a safe location prior to editing.
  • Once edited, reload the VM to inventory using ESXi CLI (see KB 343248 for detailed steps).
    vim-cmd vmsvc/reload VMid
  • Power on the VM from ESXi CLI (see KB 345049 for detailed steps)
    vim-cmd vmsvc/power.on VMid
In the vCenter UI, confirm that all actions against the VM are working (power on-off / vMotion, etc.).
