Resource Pools Do Not Display CPU Usage of Virtual Machines
Article ID: 381106
VMware vSphere ESXi VMware vCenter Server 7.0 VMware vCenter Server 8.0
When observing the Resource Pool Capacity and Usage in vSphere client, CPU or memory usage may show lower than expected, or have a zero value.
  • vCenter Server 7.x
  • vCenter Server 8.x.
Resource pool usage will show resource reservations only. If no reservations are set on a VM in a resource pool, the current CPU and memory usage will not be displayed at the resource pool UI.
You can see current resources utilization in Monitor/Utilization tab.
  • vSphere Inventory -> Hosts and Clusters view -> Click on Resource Pool -> Monitor (tab) -> Overview> (filter) -> Resource Pool and Virtual machines
Set CPU reservations on VMs on a needed basis when grouped under child resource pools.
For more information on resource pool usage and charts, visit the vSphere Monitoring Performance page.
