<edge-hostname>(tier0_sr[X])> get interfaces statsThu Oct 10 2024 UTC 10:04:27.501Logical RouterUUID : ########-####-####-####-########8d5dVRF : 2LR-ID : 2Name : SR-<Tier-0 name>Type : SERVICE_ROUTER_TIER0Statistics Interface Type RX PKTS TX PKTS RX BYTES TX BYTES RX Drops TX Drops...########-####-####-####-########4ae6 lif 1981668 2357444 176450467 148213009 43 412108
<edge-hostname>> get tunnel-port Resolution requires configuration changes on the fabric level, outside of NSX scope.
To eliminate packet loss and issues where network traffic is being blackholed, it is recommended to use Edge nodes in single homed setup (instead of multi-homed).
