KNOWN ISSUE: DS and GSS issue with Windows 11 24H2/LTSС 2024: Windows partition is not accessible from Preboot
Article ID: 380892
Deployment Solution Ghost Solution Suite
Microsoft has introduced new installation wizard with Win11 24H2/LTSС 2024 that incorrectly sets attributes for Windows partition.
This may result in:
  • duplicate computer records
  • issues with static IP
  • fail to copy Preboot logs
Basically, any action that needs to copy file to/from Windows partition in WinPE while using GSS 3.3.x or Deployment Solution 8.7.x/8.8
DS 8.7.x-8.8 GA
GSS 3.3.x
changes done in Win11 24H2/LTSС 2024 for installation wizard.
Issue is resolved starting from DS 8.8.1 release.
For the previous versions please perform the following steps:
Steps to be performed manually using the built-in 'diskpart' tool:
select volume C:
detail volume
There is an additional issue in diskpart tool not being able to display the issue.
Run the following commands to view real volume attributes:
select disk <nr>
select partition <nr>
detail partition
Notice that the actual attribute doesn't equal to '0'
Run the following commands to fix the issue:
select volume C:
attributes volume clear noDefaultDriveLetter
Then verify that the actual attribute equals to '0'
After this step - both DS and GSS can access and work with the drive for further imaging and other tasks.
