3NIC Azure Virtual Edge trouble FAQs
Article ID: 380229
VMware VeloCloud SD-WAN
If you have created Azure Virtual Edge using the 3NIC ARM template that was provided in 2022, the some issues may occur.
This article answers FAQs related to 3NIC Azure Virtual Edge issue.
*3NIC Azure Virtual Edge is an Azure Virtual Edge, which has GE1 switch port, GE2 routed port(overlay) and GE3 routed port(non-overlay) like below.
Velocloud SDWAN, VMware SDWAN, Azure Virtual Edge
Edges started in mgmt-only mode when upgrade to 5.2.3+
This issue is related to the following KB.
Edges started in mgmt-only mode when upgrade to R5233
Unavailable public IP
You need upgrading a basic public IP address to Standard SKU by 2025/9/30.
The guidance is the following.
Upgrading a basic public IP address to Standard SKU - Guidance
Upgrading to version 5.2.3+ takes over 80 minutes
If you are facing this issue, you will need to contact VeloCloud support. Refer to this kb while engaging the support.
Attached file is the 3NIC ARM template guide page that was provided in 2022 (Japanese language version)
sd-wan-azure-virtual-edge-deployment-guide.pdf get_app
