State: "Failed-An error occurred while opening configuration file "/vmf/volumes/datastore/VM/VM.vmx":Insufficient permission to access the file
Errors An error occurred while opening configuration file "/vmf/volumes/datastore/VM/VM.vmx"
Cannot open the configuration file "/vmf/volumes/datastore/VM/VM.vmx"
Failed to start the virtual machine (error -18).
vmware.log of VM shows similar entries as belowyyyy-mm-ddThh:mm:ss No(00) vcpu-0 - ConfigDB: Setting scsi0:0.fileName = "VM-000001.vmdk"yyyy-mm-ddThh:mm:ssWa(03) vcpu-0 - FILE: FileIO_Lock on '/vmfs/volumes/datastore/VM/VM.vmx' failed: Permission deniedyyyy-mm-ddThh:mm:ss Wa(03) vcpu-0 - FILE: FileIO_Lock on '/vmfs/volumes/datastore/VM/VM.vmx' failed: Permission deniedyyyy-mm-ddThh:mm:ss In(05) vcpu-0 - Msg_Reset:yyyy-mm-ddThh:mm:ss In(05) vcpu-0 - [msg.configdb.open] An error occurred while opening configuration file "/vmfs/volumes/datastore/VM/VM.vmx": Insufficient permission to access the file.yyyy-mm-ddThh:mm:ss In(05) vcpu-0 - [msg.configdb.open] An error occurred while opening configuration file "/vmfs/volumes/datastore/VM/VM.vmx": Insufficient permission to access the file.yyyy-mm-ddThh:mm:ss In(05) vcpu-0 - ----------------------------------------yyyy-mm-ddThh:mm:ssIn(05) vcpu-0 - SNAPSHOT: SnapshotConfigWrite: Failed to write config file '/vmfs/volumes/datastore/VM/VM.vmx'.yyyy-mm-ddThh:mm:ss Cr(01) vcpu-0 - PANIC: Critical snapshot error.yyyy-mm-ddThh:mm:ss In(05) vcpu-0 - Backtrace:yyyy-mm-ddThh:mm:ss verbose hostd[2099613] [Originator@6876 sub=Vigor.Vmsvc.vm:/vmfs/volumes/datastore/VM/VM.vmx <opID> user=vpxuser Commit Vigor batch operation failed: vim.fault.GenericVmConfigFaultyyyy-mm-ddThh:mm:ssverbose hostd[2099613] [Originator@6876 sub=Vigor.Vmsvc.vm:/vmfs/volumes/datastore/VM/VM.vmx <opID> user=vpxuser Commit Vigor batch operation message: Unable to write VMX file: /vmfs/volumes/datastore/VM/VM.vmx.--> Insufficient permission to access the file[....]yyyy-mm-ddThh:mm:ss info hostd[2099613] [Originator@6876 sub=Libs <opID> user=vpxuser SNAPSHOT: SnapshotDeleteVMInt failed: Insufficient permission to access the file (3)yyyy-mm-ddThh:mm:ss verbose hostd[2099613] [Originator@6876 sub=Vigor.Vmsvc.vm:/vmfs/volumes/datastore/VM/VM.vmx <opID>= Delete VM translated error to vim.fault.CannotAccessFileyyyy-mm-ddThh:mm:ss verbose hostd[2099613] [Originator@6876 sub=Vigor.Vmsvc.vm:/vmfs/volumes/datastore/VM/VM.vmx <opID> user=vpxuser Delete VM message: Failed to delete the virtual machine, '/vmfs/volumes/datastore/VM/VM.vmx'.
vmware.log will show similar entries as belowyyyy-mm-ddThh:mm:ss Wa(03) vmx - FILE: FileIO_Lock on '/vmfs/volumes/datastore/VM/VM.vmx ' failed: Permission deniedyyyy-mm-ddThh:mm:ss Wa(03) vmx - FILE: FileIO_Lock on '/vmfs/volumes/datastore/VM/VM.vmx ' failed: Permission deniedyyyy-mm-ddThh:mm:ss In(05) vmx - Msg_Reset:yyyy-mm-ddThh:mm:ss In(05) vmx - [msg.configdb.open] An error occurred while opening configuration file "/vmfs/volumes/datastore/VM/VM.vmx ": Insufficient permission to access the file.yyyy-mm-ddThh:mm:ss In(05) vmx - [msg.configdb.open] An error occurred while opening configuration file "/vmfs/volumes/datastore/VM/VM.vmx ": Insufficient permission to access the file.yyyy-mm-ddThh:mm:ss In(05) vmx - ----------------------------------------yyyy-mm-ddThh:mm:ss Wa(03) vmx - Migrate: Failed to write out config file.yyyy-mm-ddThh:mm:ssIn(05) vmx - Migrate: Caching migration error message list:
Packet capture command - tcpdump-uw -i vmk0 -vv -n host <NFS aarray IP> -w /test.pcap
This is caused when Fpolicy is enabled on the Netapp NFS Server.
This is not due to ESXi NFS client but from the NFS server array. Contact Netapp Support for further assistance.
