Does the Tibco EMS monitor agent supports fault tolerance? For example, we installed EMS monitoring agent on server A and Server 'A' failed due to some issue but monitoring should be continue using server 'B', Once Server A comes up, then monitoring should switch to server A.
Consider installing the TIBCO EMS monitoring agent on both server A and B using the same agent naming configuration for the fault tolerance monitoring requirement.
