No Power Supply metrics for Cisco switches in PM
Article ID: 379546
Network Observability CA Performance Management
Performance Management has not discovered any Power Supply Metric Families for Cisco switch devices.
Performance Management: Any version
The Power Supply Metric Families is associated with the "F5 Network Systems" Monitoring Profile:
The "F5 Network Systems" Monitoring Profile is not associated with any Collection OOB:
The discovered devices are related to the following Group Names OOB:
  • All Devices
  • All Manageable Devices
  • All Switches
Here are the steps to associate the "F5 Network Systems" Monitoring Profile the devices:
1. First create a custom group if there is none.
2. Supply the Group Name and Description:
3. Create a new Rule for the new custom group:
4. For this example, we are adding only Router and Switch device types:
5. Save the Rule:
6. Expand the Items and check whether the devices were added to the group:
7. Make a copy of the "F5 Networks Systems Monitoring Profiles:
8. Supply the Name, Description, and add the Metric Families:
9. Assign the "Power Supply for Network Infra" Monitoring Profile to the custom Collection:
10. The Power Supply Metric Families were discovered on the devices:
Create a Component Filter in DX NetOps Portal
https://www.youtube.com/watch?v=r67thWLD9_A
