Symptoms:
Exit code of install/update of release identity-service is 1
+ return 1
Failure counts are 1, from 1 finished
services-logs/prelude/identity-service-app/file-logs/identity-service-app.log the following AnnotatedNoRouteToHostException Error can be seen<Timestamp> ERROR identity-service [host='identity-service-app-<pod id>' thread='reactor-http-epoll-1' user='' org='' trace='<guid>'] c.v.i.common.util.HealthUtilComponent.onErrorMarkDown:36 - null: vidm.tenant.fqdn/192.168.0.1:443; nested exception is io.netty.channel.AbstractChannel$AnnotatedNoRouteToHostException: null: vidm.tenant.fqdn/192.168.0.1:443
org.springframework.web.reactive.function.client.WebClientRequestException: null: vidm.tenant.fqdn/10.146.8.170:443; nested exception is io.netty.channel.AbstractChannel$AnnotatedNoRouteToHostException: null: vidm.tenant.fqdn/192.168.0.1:443
Aria Automation 8.x, VMware Identity Manager 3.3.x
Aria Automation has no connection to the VMware Identity Manager tenant.
This is an environmental issue, to resolve please review/correct the routing from Aria Automation nodes to VMware Identity Manager tenant.
