Timesheet rule does not work when no value is present in Timesheet Grid
Article ID: 377697
Clarity PPM On Premise Clarity PPM SaaS
Steps to Reproduce:
  1. Define a Timesheet rule to have at least 8 hours of time reported each day
  2. Add a few tasks to a timesheet
  3. Do not enter any value
  4. Click on Submit
    Expected Result: Timesheet rule throws an error
    Actual Result: Timesheet gets submitted. Null values in the Timesheet Grid is not being considered as 0 hours.
  5. Enter 1 hour against any cell in the Grid
  6. Click on Submit
    Actual Result: Timesheet rule throws an error.
Version(s):
  • Tested on 16.2.3 as of this writing.
DE154059
DE154059 is fixed in 16.3.0.
Workaround:
  • Create Time Entry Error Condition rule using the 'Sum of Entries'  - Daily Sum < 8.
