Problems with MQ thresholds after applying ptf LU13237
Article ID: 377659
SYSVIEW Performance Management
With the correct  syntax (as defined at rel 16.0) nothing happens at Sysview 17.0 when entering the command RULES MQ THR
The threshold defined:
)THRESHOLDS MQSDATA-BUFPOOLS YES
)THRESHOLDS MQSDATA-CHANNELS YES
)THRESHOLDS MQSDATA-DQMGRS   YES
)THRESHOLDS MQSDATA-PAGESETS YES
)THRESHOLDS MQSDATA-QMGRS    YES
)THRESHOLDS MQSDATA-QUEUES   YES
DEFINE    MQ_QUEU_DeadLetterDepth
 SCOPE    =
 NAME =.DEAD.=
 QUAL     =
 ATTR     =
 ENABLED
 RULETYPE UPPER
 TYPE     SYSTEM
 TRIGLVL  CHANGE
 PROBLEM  1
 WARNING  1
 WARNPCT  100
 DURATION 2
 PRIORITY 0
 CAPLEVEL NONE
 CAPEVENT *
 CAPTIME  00:15:00
 MSG      YES
 LOG
 SMF
 OPSMVS     OPSMVSEVENT CAGSVS0001
 NOACNOTIFY NOACTICKET
 IMOD     NO  IMODNAME *
 NOTRAP         TRAPDEST *
 SUN   MON   TUE   WED   THU   FRI   SAT
  TIMEBEGIN  00:00:00
 TIMEEND    23:59:59
 DESCRIPTION 'Dead letter queue depth                 '
ENDDEFINE
Sysview release 17.0
The threshold definition is correct, only ptf LU13237 introduced a problem with the MQ thresholds.
Install ptf LU14079 to correct the error.
Even though it is not mentioned in ptf LU14079 it is solving MQ thresholds, it also solves the issue.
However ptf LU14079 is marked in ERROR and the RESOLVER is ptf LU14229 and LU14466
