/var/log/vmware/vpxd-svcs, errors like in the following example can be found:XXXX-XX-XXT11:26:26.096+08:00 [tomcat-exec-272 [] INFO com.vmware.vim.sso.client.impl.SecurityTokenServiceImpl opId=] Successfully acquired token for user: {Name: USERNAME, Domain: VSPHERE.LOCAL}XXXX-XX-XXT11:26:26.096+08:00 [tomcat-exec-272 [] INFO com.vmware.cis.authorization.impl.AuthorizationManagerImpl opId=] Session count for user [after add]: VSPHERE.LOCAL\USERNAME is 200XXXX-XX-XXT11:26:26.107+08:00 [tomcat-exec-250 [] INFO com.vmware.identity.token.impl.SamlTokenImpl opId=] SAML token for SubjectNameId [[email protected], format=http://schemas.xmlsoap.org/claims/UPN] successfully parsed from ElementXXXX-XX-XXT11:26:26.107+08:00 [tomcat-exec-250 [] WARN com.vmware.cis.authorization.impl.AuthorizationManagerImpl opId=] Session limit reached for user: VSPHERE.LOCAL\USERNAME with 200 sessions.XXXX-XX-XXT11:26:26.107+08:00 [tomcat-exec-250 [] ERROR com.vmware.vim.vcauthenticate.servlets.AuthenticationHelper opId=] Authentication error: com.vmware.vim.vcauthenticate.exception.VimAuthenticateException: com.vmware.cis.core.exception.AuthorizationException: Too many sessions for user: VSPHERE.LOCAL\USERNAME with 200 sessions.XXXX-XX-XXT11:26:26.107+08:00 [tomcat-exec-250 [] WARN com.vmware.vapi.internal.bindings.ApiMethodSkeleton opId=] Implementation method reported unexpected exception: java.lang.RuntimeExceptionjava.lang.RuntimeException: Rejecting login on a session where login failed at com.vmware.cis.services.common.vapi.sessions.impl.VlsiBackedSessionManager.loginInt(VlsiBackedSessionManager.java:164) [service-common.jar:?]
VMware vCenter Server 7.0.x
VMware vCenter Server 8.0.x
Endpoint Limits for Concurrent REST Requests.
The issue occurs when the available session limit for the REST API has been exhausted
The maximum number of sessions that can be open for the REST API is limited to 200 per user, as soon as there are 200 concurrently open sessions for the API by this user, any attempt to open a further session will be denied, leading to the error above.
$ grep "/sdk HTTP/2 500 via_upstream.*<SOURCEIP>" envoy-access-9057.logXXXX-XX-XXTXX:XX:XX.XXXX info envoy[140390803613504] [Originator@6876 sub=Default] XXXX-XX-XXT03:26:22.718Z POST /sdk HTTP/2 500 via_upstream - 1135 703 3 3 0 <SOURCEIP>:41770 XX.XX.XX.XX:443 127.0.0.1:59512 127.0.0.1:8085XXXX-XX-XXT03:26:23.XXXX info envoy[140390803613504] [Originator@6876 sub=Default] XXXX-XX-XXT03:26:23.016Z POST /sdk HTTP/2 500 via_upstream - 1135 703 4 4 0 <SOURCEIP>:41770 XX.XX.XX.XX:443 127.0.0.1:59512 127.0.0.1:8085XXXX-XX-XXT03:XX:XX.XXXX info envoy[140390803613504] [Originator@6876 sub=Default] XXXX-XX-XXT03:26:23.954Z POST /sdk HTTP/2 500 via_upstream - 1135 703 4 4 0 :41852 XX.XX.XX.XX:443 127.0.0.1:49632 127.0.0.1:8085<SOURCEIP>
$ grep 'HTTP/1.1" 500' endpoint-access.logXXXX-XX-XXT11:26:26.109+08:00 | vAPI-I/O dispatcher-1 | XX.XX.XX.XX - - [12/Sep/2024:03:26:25 +0000] "GET /rest/com/vmware/cis/tagging/category HTTP/1.1" 500 351 "-" "terraform-provider-vsphere_v2.8.1_x5 govmomi/0.37.1 (go1.22.2;linux;amd64)" 281XXXX-XX-XXT11:26:26.116+08:00 | vAPI-I/O dispatcher-0 | XX.XX.XX.XX - - [12/Sep/2024:03:26:25 +0000] "GET /rest/com/vmware/cis/tagging/category HTTP/1.1" 500 351 "-" "terraform-provider-vsphere_v2.8.1_x5 govmomi/0.37.1 (go1.22.2;linux;amd64)" 280XXXX-XX-XXT11:31:28.777+08:00 | vAPI-I/O dispatcher-0 | XX.XX.XX.XX - - [12/Sep/2024:03:31:28 +0000] "POST /rest/com/vmware/cis/tagging/tag-association?~action=list-attached-tags HTTP/1.1" 500 351 "-" "terraform-provider-vsphere_v2.8.1_x5 govmomi/0.37.1 (go1.22.2;linux;amd64)" 167XXXX-XX-XXT11:31:31.161+08:00 | vAPI-I/O dispatcher-0 | XX.XX.XX.XX - - [12/Sep/2024:03:31:31 +0000] "POST /rest/com/vmware/cis/tagging/tag-association?~action=list-attached-tags HTTP/1.1" 500 351 "-" "terraform-provider-vsphere_v2.8.1_x5 govmomi/0.37.1 (go1.22.2;linux;amd64)" 149
XXXX-XX-XXT11:26:26.096+08:00 [tomcat-exec-272 [] INFO com.vmware.vim.sso.client.impl.SecurityTokenServiceImpl opId=] Successfully acquired token for user: {Name: USERNAME, Domain: VSPHERE.LOCAL}XXXX-XX-XXT11:26:26.096+08:00 [tomcat-exec-272 [] INFO com.vmware.cis.authorization.impl.AuthorizationManagerImpl opId=] Session count for user [after add]: VSPHERE.LOCAL\<USERNAME> is 200XXXX-XX-XXT11:26:26.107+08:00 [tomcat-exec-250 [] INFO com.vmware.identity.token.impl.SamlTokenImpl opId=] SAML token for SubjectNameId [[email protected], format=http://schemas.xmlsoap.org/claims/UPN] successfully parsed from ElementXXXX-XX-XXT11:26:26.107+08:00 [tomcat-exec-250 [] WARN com.vmware.cis.authorization.impl.AuthorizationManagerImpl opId=] Session limit reached for user: VSPHERE.LOCAL\<USERNAME> with 200 sessions.XXXX-XX-XXT11:26:26.107+08:00 [tomcat-exec-250 [] ERROR com.vmware.vim.vcauthenticate.servlets.AuthenticationHelper opId=] Authentication error: com.vmware.vim.vcauthenticate.exception.VimAuthenticateException: com.vmware.cis.core.exception.AuthorizationException: Too many sessions for user: VSPHERE.LOCAL\USERNAME with 200 sessions.XXXX-XX-XXT11:26:26.107+08:00 [tomcat-exec-250 [] WARN com.vmware.vapi.internal.bindings.ApiMethodSkeleton opId=] Implementation method reported unexpected exception: java.lang.RuntimeExceptionjava.lang.RuntimeException: Rejecting login on a session where login failed at com.vmware.cis.services.common.vapi.sessions.impl.VlsiBackedSessionManager.loginInt(VlsiBackedSessionManager.java:164) [service-common.jar:?]
In this example, the user VSPHERE.LOCAL\<USERNAME> holds 200 open REST API sessions at the same time, thus exhausting its session limit. .
To resolve this, please modify the automation script to ensure it does not the maximum limit of 200 concurrent API sessions number this 200-session limit for a single user. This can be achieved by implementing proper session management techniques, such as:
For more information please refer to https://blogs.vmware.com/performance/2022/07/endpoint-limits-for-concurrent-rest-requests-from-vcenter-apis.html
