VCMP tunnel (between edge and VCG) flaps when VCG certificate is renewed
Article ID: 376642
VMware VeloCloud SD-WAN
The problem is related to to gateway certificate renewal. Whenever gateway certificate is renewed(usually once a ~month timeframe)
the gateway brings down all tunnels and reestablishes again. All customer at renewal time will encounter tunnel flapping for some short period of time.
There is no workaround available. The issue is fixed in 5.2.3 and above release
