DHCP relay will not work when DHCP servers are reachable through a Non SD-WAN Destination via Edge
Article ID: 376634
Updated On: 09-11-2024
VMware VeloCloud SD-WAN Edge Appliance
Edge's clients do not get IP addressing information using DHCP when the DHCP server(s) is located behind a Non SD-WAN Destination via Edge, and Edge acts as a relay agent
All software versions
There is currently no Support for the specific functionality on any Software version. Issue is tracked by internal ticket #75171, kindly reach to your Sales Engineer/Sales Representative, if you would like to request Support for this feature
