Workpoint delay operator not proceeding. WP.logs return the following:
"2024-05-09 15:26:04,038 [Worker_jobq#JobQ1#WPDS_2] ERROR [] com.workpoint.server.script.ScriptEngine - A script error has occurred. Error occurred in Statement #1 in Script ID 2726:WPDS, Script Name = 'Terminate_SubProcess', Script type = 'Transition Selection'. Job ID = XXXXX:WPDS, Process Ref = 'myIdM_User_Term', Transition ID = 727666218:WPDS, Transition Name = 'Terminate_SubProcess', Transition Source Node Name = 'LaunchTerminate', Destination Node Name = 'Node 21'
com.workpoint.common.exception.ScriptEngineException: A Throwable error was caught when executing script. Error Message='org.mozilla.javascript.WrappedException: Wrapped java.lang.NullPointerException (WorkPointScript#33)',
Or a ClassNotFoundException such as:
Exception in thread "Query_jobq#JobQ1#WPDS" java.lang.NoClassDefFoundError: com/workpoint/json/data/RequestDataTranslator
2025-02-18 14:17:12,938 ERROR [stderr] (Query_jobq#JobQ1#WPDS) at com.workpoint.queue.query.JobQQueryThread.A(Unknown Source)
2025-02-18 14:17:12,938 ERROR [stderr] (Query_jobq#JobQ1#WPDS) at com.workpoint.queue.query.JobQQueryThread.performQuery(Unknown Source)
2025-02-18 14:17:12,938 ERROR [stderr] (Query_jobq#JobQ1#WPDS) at com.workpoint.queue.query.QQueryThread.run(Unknown Source)
2025-02-18 14:17:12,938 ERROR [stderr] (Query_jobq#JobQ1#WPDS) Caused by: java.lang.ClassNotFoundException: com.workpoint.json.data.RequestDataTranslator from [Module "deployment.iam_im.ear"
Identity Manager = 14.4, 14.5
