Aria Automation & Aria Automation Orchestrator potentially impacted by CVE-2024-34750
Article ID: 376127
VMware Aria Automation & Standalone Aria Automation Orchestrator potentially impacted by CVE-2024-34750
Aria Automation 8.18.0
Aria Automation Orchestrator 8.18.0
Improper Handling of Exceptional Conditions, Uncontrolled Resource Consumption vulnerability in Apache Tomcat. When processing an HTTP/2 stream, Tomcat did not handle some cases of excessive HTTP headers correctly. This led to a miscounting of active HTTP/2 streams which in turn led to the use of an incorrect infinite timeout which allowed connections to remain open which should have been closed.
Please Refer :  https://nvd.nist.gov/vuln/detail/CVE-2024-34750
Broadcom VCF Support is aware of the CVE and it will be fixed in next release of VMware Aria Automation.
