Maps do not load in Home and Physical Data Center views on VMware Aria Operations
Article ID: 375283
While adding physical data centers in VMware Aria Operations, unable to view the world map as seen in screenshot below.
Following is the screenshot from working environment:
VMware Aria Operations 8.x
Internet is not enabled on the browser from where the Aria Operations is being accessed.
Aria operations need access to following map provider URLs in order to display the map on console. Hence, make sure either the internet is accessible in the browser or following URLs are whitelisted.
  • tile.openstreetmap.org
  • tile.jawg.io
For more information on how to add physical data centers in VMware Aria Operations, check the documentation.
