SD-WAN Edge 710, traffic from Wireless clients might be impacted after enabling High Availability
Article ID: 373964
VMware VeloCloud SD-WAN
This issue is specific to the 710 Edge Platform. If the configuration of the Edge includes VLANs associated only with a wireless interface (WLAN) and High Availability is enabled on the Orchestrator, traffic from wireless clients on that VLAN might fail
VMware SD-WAN by VeloCloud
Edge platform 710
Issue is caused by repercussions of Software Defect #118710
Complete fix for the specific issue is planned to be included on versions 5.2.4 and version 6.1.0, so the recommendation would be to upgrade to a version with the fix
