Power outage/Abrupt shutdown of Aria operations appliance triggering '"High memory workload caused by Guest Memory Needed metric not being collected" alert for VM objects.
Article ID: 373818
Alert "High memory workload caused by Guest Memory Needed metric not being collected" is triggered due to Memory|Workload% metrics in Aria operations is higher than the guest OS Memory usage in VM.
Aria Operations 8.16.x
Aria operations stops collecting Virtual Machine guest stats through VMware tools. Memory|Utilization metric falls back to using Memory|Consumed rather than guest needed memory.
Follow the steps to start recollecting the VM guest stats through VMware tools:
  • Put host in maintenance mode and power cycle the host.
  • Restart VM-tools on virtual machine.
