All AIX Robots in Error after Trying to Upgrade robots to 23.4.1 using the robot_update in archive, Error:
root@XXX:/opt/CA/bin > ./nimbus start exec ():
0509-036 Cannot load program ./nimbus because of the following errors:
0509-150 Dependent module /usr/lib/libiconv.a(libiconv.so.2) could not be loaded.
0509-152 Member libiconv.so.2 is not found in archive
UIM:23.4.X
OS:AIX
Robot 23.4.x need libiconv.so.2 which is part of third party libiconv, this lib is not part of standard AIX OS
Download and apply hotfix nimsoft-robot.aix6.1.ppc64.rpm attached to case below.
