ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
SRM has not finished starting after upgrade
Article ID: 37353
CA Spectrum
Symptom:
After upgrading to CA Spectrum 9.4.x, fails to launch the InfoView, the following message error is displayed:
Environment:
CA Spectrum 9.3.x/9.4.x
CABI 3.3 SP1
Cause:
The SRM is failing to apply schema change to add the isClusterEntity column to the model table for cluster information.
The following error is found in the $SPECROOT/tomcat/logs/stdout.log (or catalina.out) file:
jan 26, 2016 08:21:05 AM (SRM/Startup/Container) (com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeUpdater) - (ERROR) - Error occurred while applying schema change
Name: 1068 (Product version: 9.3.2) - Adding isClusterEntity column to model table for cluster information
com.aprisma.spectrum.app.web.db.schemachange.FatalSchemaChangeException: com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeException: SQLException while running RuntimeSchemaChange1068 Schema Change Errorcode: 1060
Caused by: com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeException: SQLException while running RuntimeSchemaChange1068 Schema Change Errorcode: 1060
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Duplicate column name 'isClusterEntity'
As per the output of the following MySQL query, the 'isClusterEntity' column already exists in the model table:
1. Open a bash shell (bash –login)
2. Navigate to $SPECROOT/mysql/bin directory
3. Launch the MySQL command line interface
Run: ./mysql -uroot -proot reporting (for Windows platform)
Run: ./mysql --defaults-file=../my-spectrum.cnf -uroot -proot reporting (for Linux/Solaris platform)
mysql> show full columns from model;
| Field            | Type             | Collation         | Null | Key | Default             |
| model_key        | int(10) unsigned | NULL              | NO   | PRI | NULL                |
| model_h          | int(10) unsigned | NULL              | NO   | MUL | 0                   |
| model_name       | varchar(4000)    | latin1_swedish_ci | YES  | MUL | NULL                |
| mtype_h          | int(10) unsigned | NULL              | YES  | MUL | NULL                |
| model_class      | int(10) unsigned | NULL              | YES  | MUL | NULL                |
| network_address  | varchar(255)     | latin1_swedish_ci | YES  |     | NULL                |
| first_event_time | datetime         | NULL              | YES  |     | 2000-01-01 00:00:00 |
| landscape_h      | int(10) unsigned | NULL              | YES  | MUL | NULL                |
| destroy_time     | datetime         | NULL              | YES  | MUL | NULL                |
| security_string  | varchar(255)     | latin1_swedish_ci | YES  | MUL | *UNKNOWN*           |
| isClusterEntity  | int(11)          | NULL              | NO   |     | 0                   |
11 rows in set (0.00 sec)
Run the following MySQL query to find the last entry in the schemaversion table and take note of change_id value:
mysql> select * from schemaversion order by change_id desc limit 1\G
*************************** 1. row ***************************
change_id: 221
session_id: 156
category: DataProcessing
schema_comments: Adding isClusterEntity column to model table for cluster information
major: 9
minor: 3
service_pack: 2
start_time: 2016-01-26 08:21:05
end_time: NULL
duration_secs: NULL
state: F
state_details: com.aprisma.spectrum.app.web.db.schemachange.SchemaChangeException: SQLException while running RuntimeSchemaChange1068 Schema Change Errorcode: 1060
Resolution:
Run the following MySQL command line in the MySQL prompt to change the state column from "F" to "A" of the last change_id entry in the schemaversion table and restart the Spectrum Tomcat service.
1. Open a bash shell (bash -login)
2. Go to $SPECROOT/mysql/bin directory
mysql>update schemaversion set state='A' where change_id=221;
Stop/Start the Spectrum Tomcat service for the changes to take effect.
Release: SPDBIP99000-9.3-Spectrum-Device Based Suite-IP Services Manager
Component:
